hello
in the last few days i found a strange problem - when saveing changes on wirelless settings then sometimes only a few clients connect - after doing the save again ore interface on/off the clients connect again or not …
sometimes it needs a few gos
somtimes the clients are connected and no data is transmitted
ore somtimes they are connected and data is moved over very slow - ping is about 3000ms
and it only happens an the bottom card of the rb532 - never on the one on top !!
i also tried older software versions from 2.9.19 on - same behavier
tried cm9, rb52, wlm54g- all the same
any idea - here is the config of the wlan ifs, they are bridged to eth1
0 R name=“WL1_AP_Muthmannsdorf” mtu=1500 mac-address=00:0B:6B:34:55:54
arp=enabled disable-running-check=no interface-type=Atheros AR5213
radio-name=“krh-muthmannsdorf” mode=ap-bridge ssid=“funkwolke” area=“”
frequency-mode=regulatory-domain country=austria antenna-gain=0
frequency=2417 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=50
ack-timeout=55 tx-power=15 tx-power-mode=all-rates-fixed
noise-floor-threshold=default periodic-calibration=enabled
periodic-calibration-interval=660 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=yes
security-profile=radius disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
1 R name=“WL2_AP_Maiersdorf” mtu=1500 mac-address=00:0B:6B:34:55:19
radio-name=“krh-maiersdorf” mode=ap-bridge ssid=“funkwolke” area=“”
frequency=2412 band=2.4ghz-b scan-list=default rate-set=default
54Mbps
ack-timeout=60 tx-power=15 tx-power-mode=all-rates-fixed
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=600 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
proprietary-extensions=pre-2.9.25 hide-ssid=yes security-profile=radius
