Wireless clients Shaping
Is there a solution to shape traffic between wifi clients connected to AP
1 - shape speed in access list
2 - route? how? didn’t work
3 - any ideas?
Access-list is working only between MikroTik Routers.
But you can use regular queues to apply bandwidth shaping,
http://www.mikrotik.com/testdocs/ros/3.0/qos/queue.php
Help!!! It is Necessary see example/ :frowning:
There are examples in the manual and wiki
tried all, not to shape traffic between wifi clients connected to AP. Help. Needs worker an example
Cant you read? its BETWEEN AP CLIENTS
and needet to be shaped Between wifi clients connected to mikrotik
So if you wanted to shape the bandwidth between the clients on a wifi network connected to a particular ap, they you would bind the cleints mac address to an ip address and then use the http://www.mikrotik.com/testdocs/ros/3.0/qos/queue.php to in order to shape the bandwidth between the clients, now if the clients talk to each other without useing the gateway of the routeros, then the clients would need thier own shaping done on the client side, which can be done easily on every wifi client that is running routeros , but true laptop accounts that just use the wifi card in the laptop would be unaffected
Sorry for misunderstanding. IT is not possible to limit traffic between
wireless clients with mangle and queues, because Router is not seeing traffic
between clients.
Only solution to limit this kind of traffic is to set default-ap-tx-limit in
wireless interface settings or set ap-tx-limit to wireless access list
entries.
Note that client-tx-limit will work only if wireless client is mikrotik device
too.
Regards,
Maris
Сan through routing possible?
