i use dhcp to push capsman server address。
on ap if use wireless-cm2 package fail,but use wireless-fp is ok。 ![]()
just checked with the RouterOS v6.34rc and it was working fine.
On the CAP DHCP-Client I see the CAPs Managers IP address.
What version and what boards you are using on CAPsMAN, DHCP Server and CAP?
thanks for your rep.
i think maybe capsman server use wireless-fp package,ap must use the same package with capsman server. ![]()
