I have set up mikrotik (v.5.24) hotspot with one user. The access point is not encrypted with security protocol.
- The client (for example a smart phone) see an unlocked wifi signal and then they connect on it.
- Login page appears and the client enter the credentials (username and password).
- The client now can surf to the internet successfully.
- The smart phone gets idle.
- After one minute the smart phone is enabled again in order to surf to the internet.
- The smart phone doesn’t reconnect again to the unlocked wifi signal.
- The client has to choose again the wifi signal and enter again the credentials.
I have session timeout: 1 hour
Idle timeout: none
keepalive timeout: 2m
The cookies are enabled. And I use only one user for all terminals and set the Shard Users: 300
Why after the device is idle the mikrotik reasks for credentials although I have enabled Cookies?
Regards
