hi m8’s!
What could be the problem, if i receive always “class 3 frame received”? What does it mean!?
thnx
hi m8’s!
thnx
You could post some more information about your config - so everybody can only guess.
A class 3 frame in 802.11 wireless is a data frame, and guessing on your post, I suppose the log message wants to tell you that the AP received a data frame from a device not correctly authenticated/associated to the AP.
Best regards,
Christian Meis
so. i have a wrap.2c with cm9 wlan card. mt 2.9.6. the clients are PC6860 pci cards and one wx-7800a sparklan in client mode. the ap is at 5ghz. there are 3 pci clients and the sparklan. if the spark is connected, one of the client can connect but the others no. when the spark is off, all clients can access the AP, and after if i switch on the sparklan, the clients are remain connected. but after pc reboot, they can’t connect again till i switch off the spark.
already changed cables(rf240), the cards, but it’s still the same. also changing freq doesnt take affect.
could it be a problem of the antenna, or the mt!?
thnx in advance
p.s: the exact log is “disconnected xx:xx:xx:xx:xx:xx, got deauth: class 3 frame received(7)”
Esetleg ha van kedved jerr fel az sst pont jetos pont com oldalra 1 kis eszmecsere érdekében
ha gondolod és van kedved.
Üdv Slys!
