Wireless desconect with a good signal
Have in my log:
wlan1: data from unknown device XX:XX:XX:XX:XX:XX, sent deauth (9 events suppressed, 112 deauths suppressed)
This interface operate in a bridge WDS with STP.
The connection is losed about 30s and reconect.
XX:XX… refer a known MAC address and it is in access list.
Why this?
i have the same problem but it never reconnect again i have to reboot the pc router so i can reconnect "did you solve your problem and what was it please???
I belive why the power force problems.
I will make a tests in next week and will post in here if good results.
“”""What you mean in power force is it the elecricity???or power of the cards??? :unamused:
"“i think that you shouldn’t be using the stp”
it doesn’t matter if you use STP or not in this case.
well i’m just guessing coz i’m not using STP and i don’t what it stand for :unamused:
power of eletricity.
currently i’m using power over ethernet and will test without this.
referring to manual STP detects loops in netowork. and so it does :slight_smile:
STP is “Spanning Tree Protocol”. You only need it if you are running a bridged network and have your network looped. For instance: Tower A connects to Tower B, Tower B connects to Tower C, Tower C connects back to Tower A. Now if your network is bridged, this will not work without STP. In fact, it will cause a nasty bridge loop that will bring everything to its knees.
Eric
hmm this meen if i have network
tower A connected to B, B to C , C to D,E,F i don’t need to use stp ?
Nope you dont need stp, only if F was to connect back to A etc.
so i understand that if we use the stp in every bridge router we connected them all together with no worries of have a loopback link?
