Wireless disappear
Wireless interface is disappearing suddenly leaving an unknown interface in the bridge.
Of course, customers can’t connect and if the system is rebooted the config starts working again.
Model 751 U-2Hnd with firmware 5.25
Is this a documented of already fixed issue??
Thanks!
It sounds to me like you have some form of config bug going on.
I would either reset to factory settings and reconfigure it or do a netinstall and reconfigure it. I would not use a binary backup but you could shortcut the reconfiguration by using: /export file=backupFromExport
The netinstall is better in my opinion because it does a format of the storage media.
Joshaven Potter
http://joshaven.com
Sent from my iPhone using Tapatalk
