Wireless HArdware
I’ve installed mikrotik software on a x86 based pc and I wish to create an hotspot. which pci wireless card can I use? I tried with an “Hamlet”…the first that I found (just to test If the hotspot works…) but..nothing…the system doesn’t recognize it between interfaces. What should I buy?
MikroTik RouterOS supports the Intersil Prism II PC/PCI, Atheros AR5000, AR5001X, AR5001X+, AR5002X+, AR5004X+ and AR5006 chipset based cards for working as wireless clients (station mode), wireless bridges (bridge mode), wireless access points (ap-bridge mode), and for antenna positioning (alignment-only mode).
From: http://www.mikrotik.com/testdocs/ros/3.0/interface/wireless.php
And: http://www.mikrotik.com/testdocs/ros/3.0/guide/driverlist.php
