Wireless Help
Hi All,
I am newbies on Mikrotik, I bought rb112 recently with cm9-gp pci card.
I have try to connect my rb112 to an existing wireless connection with this configuration.
the internet IP is 202.93.0.0, and the existing wireless link ip is 192.168.1.0/24,
right now I can ping from the rb112 to each IPs, but if i connect the ethernet port to pc, I only can ping rb112 ethernet and wlan IP, is it possible using RB112 to coonect to the wireless connection just like enGenius radio? (the wireless IP dont have to be the same with the network)
sorry for my english
Thank in advance
Regards,
D. Yudhistira
I think I’m having exactly the same issue as you are having. Hopefully this setup is possible. RB133C trying to connect it as a wireless bridge for the wired network.
did you made some nat at new device?
no, do I have to?
:slight_smile:
itji -
First - IP address 202.93.0.0 - is a network address not a ‘station’ IP address.
Two - you need to tell us a little more info on your setup… I surmise that you are setting the RB112 in station mode. That being the case your wlan IP address would be in the range you already mentioned - 192.168.1.0/24 so the wlan would have an IP address somewhere between 192.168.1.1/24 and 192.168.1.254/24 Also somewhere there is a gateway IP address the wlan IP you are connecting to…
You didn’t actually say if this was a bridge, AP/Station or AP/WDS mode setup…need that info as well. Your answers will dictate how to proceed from here.
Thanks Galaxy,
here it is, what i need is I want to connect my rb112 to the existing senao/engenius AP. this AP set with 192.168.1.2/24 IP.
the Internet connection IP is 202.93.32.174/29, that the IP that the ISP gave to me it is a public IP.
now I can conect to the network with a senao client (3220ext) with 192.168.1.5 IP and my pc run 202.93.32.174. is it possible for me to replace the senao with my rb112?
can you tell me how to set it up?
thanks for the reply
Hi Guys i Just Wanna some Help i Want Forward my Router i have some Game and i dont now how to forwarding routers Pleace i need some help my ip is 127.0.0.1:7777 just i want to change my Router to 88.116.162.10
Thanks Yasr i hope Some One Will Help me!!
itji -
This sounds like you have a bridged setup between you and your ISP…
You will have to remove the IPs on your RB112. Then ‘add’ a bridge interface.
Add to that bridge interface eth1 and your wireless card (wlan1).
Now give the bridge this IP: 192.168.1.5/24
You have said that you PC IP is 202.93.32.174/29 , did they give you a gateway IP? Typically it would be 202.93.32.169 (the lowest IP in the block alloted), this would be the gateway you put in your PC.
Thom
thanks Tom,
I will try tomorrow and let you know as soon as I got result…
I really appreciate that,
Thank YOu Very much
Regards,
D. Yudhistira
Tom, I have tried the config, but still I can’t connect to the internet, I set 192.168.1.5 as RB’s gateway ( same with rb’s IP)
itji -
Replied to your personal email… See you there.
Thom
