wireless hosts unreachable from each other at first
hello !
i’m faced with a problem for quite some time now and i can’t seem to find a solution by myself or here in the forums…
i have a HAP AC wireless router bought some time ago, latest version from stable channel, both for routerOS and RouterBOARD
my setup is, i think, quite standard, you can find the configuration file here : https://github.com/mazerty/mikrotik/blob/master/script
as you can see, i have 3 hosts. “akhilleus” is the only one connected through cable, “hektor” and “aiolos” are connected through wireless via wlan2.
my problem is this :
if i boot up hektor and opens a terminal on aiolos, i can’t ping hektor nor hektor’s ip address
everything else works fine though : hektor can ping akhilleus, hektor can ping the router and access internet, and akhilleus can ping hektor
but for 10 minutes or so, hektor is just unreachable from aiolos, the other one connected wirelessly
then, suddenly, ping works and the host is reachable
problem is the same if it’s hektor and aiolos are reversed in the above scenario
it seems like there’s some “ip table” in the router, that only applies to wireless hosts, that takes quite some time to register online hosts…
can somebody help me ?
thanks in advance
