Wireless Hotspot Setup Challenges with mikrotik ROS & Demarc
I am new to wireless networking. i setting up a hotspots for a city and currently starting off with a base station and a repeater station. I have the following for this setup- a demarc quad base station Reliawave RWA5000, it has four radio cards insideand two ethernet ports. Three 120deg 2.4GHZ sector antenna and an omni 5GHZ. I have a x86 PC box and i have installed Mikrotik ROS 3.24. This box has two ethernet cards. one of the cards would be connected to the internet source and the other to the lan with a switch which would also connect the ethernet port from the radios outside. my problem is basically this how do i set up hotspot on the Mikrotik which would then give dynamic ips to clients connected to the radios. I have a radius server for user authentication & accounting. Is is possible? I need help pls and also how would i setup the repeater. I also have the demarc Reliawave RWA Quad basestation. Can the Router lend Ip addresses from it DHCP pool to clients cconnected on the other side of the radios
