Wireless Hotspot Setup
I am new to the Mikrotik RouterOS and just bought a RouterBoard (333) with an Antheros AR5413 Wireless MiniPCI card install. I connected the wireless card to a high gain Antenna which is working well, I am able to setup the PPPoE Server and clients which works well. I also desire to setup a Hotspot (which is possing a real problem) and after searching with google I cam accross the articles by Joe Mehaffey , but I still cant get the hotspot to work even after carefully following the instructions.
Attached here is my telnet screen while trying out the Mehaffey procedure, can anybody who has experience with this help?
Regards
TELNET Screen*******
Trying 10.5.50.1...
Connected to 10.5.50.1.
Escape character is '^]'.
MikroTik v3.0rc6
Login: admin
Password:
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 3.0rc6 (c) 1999-2007 http://www.mikrotik.com/
Terminal unknown detected, using single line input mode
[admin@MikroTik] > interface
[admin@MikroTik] /interface> print
Flags: X - disabled, R - running, D - dynamic, S - slave
NAME TYPE MTU
0 R ether1 ether 1500
1 ether2 ether 1500
2 ether3 ether 1500
3 R wlan1 wlan 1500
4 R bridge bridge 1500
5 R wds1 wds 1500
[admin@MikroTik] /interface> /ip
[admin@MikroTik] /ip> print
bad command name print (line 1 column 1)
[admin@MikroTik] /ip> /interface
[admin@MikroTik] /interface> /ip dhcp-client
[admin@MikroTik] /ip dhcp-client> set enabled=yes inteface=ether1
expected end of command (line 1 column 12)
[admin@MikroTik] /ip dhcp-client> print
INTERFACE USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS ADDRESS
0 ether1 yes yes searching...
Main steps for setting up a basic & working hotspot are:
Set a working DHCP:
  • add a pool with the desired IP range for DHCP.
  • add a dhcp → network which match the pool settings.
  • add a dhcp → server which uses the pool created, and bound to the interface which will host the hotspot.
    Test DHCP is working.
Set up Hotspot
  • Add a Hotspot server (using “+” button if using winbox or /ip hotspot add name=… if using console)
  • Bound it to the selected interface.
  • don’t select an adress pool (address-pool=none)
  • select default profile
  • add a user for testing, tied to the hotspot (or valid for all hotspots in the system):
    /ip hotspot user add comment=“” disabled=no name=“dani” password=“1234” server=hotspot1
Try it!
Hope it will help.
