Hello, i´ve got brand new hAP ax2. I removed default conf from the router and then, wireless interfaces are missing (not sure if even allocated before remove conf). Downloaded, installed wifiwave2. Configuration is okay, but e.g. cell phone is not switching between 2.4GHZ and 5GHZ. SSID and psw are same. Next: Unable to configure virtual interface. Could you please assist with this issue ? or any reason why is this happening. Is it bug or what…
Thanks for every reply.
