Thanks for help, I decided to ge rid of the amplifier and to configure the AP as client.
now, I am using amni 8db base station with 14db directional, when I try the site servey I get 30db signal, is it okay? what is the minimal signal I can have to get it work?
I keep my signal levels between -70 and -90. I’d rather not have anyone on worse than -85, but, several of my customers that average -88 are rock solid at that level. Several that have are in the -70’s will fluctuate.
Every shot is different. Right now, I have a 12dBi omni on one tower, 17dBi 120* sectors x3 on another, 15dBi omni on another. I have more customers on my 12dBi omni, even a couple that are -85 or worse, though the sectors seem more stable and are far more flexible.
90% of my customers are 19dBi Rootennas with Crossroads.
RK, actually I am using Edimax AP for testing, in the site servey section I get the wireless networks available with its signals, I get 40 for my network but I dont know if it db or not, not sure because if I put the AP a few meters from the antenna it gives maximum 60, it is kind of (40 of 60)!! I am investigating
valypetre, which of you prefer: 14db omni antenna or 3 X 120deg pannels?
I am kind of convences to go with the directional, my 8db omni has only 7 degrees veritcally broadcasting while I found directional antennas on the web that has 20deg! in my case the antenna is been installed on a mountain which is higher than the clients antennas! I need wide
angle.
