wireless issue with RB951G-2HnD
I have wireless issue with my new RB951G-2HnD
my clients once they try to connect to RB951G always get “Sign-in is Required” and once they click on sign-in will open new browser window and redirect to google.com
after (2 or 3 min) it’s will disconnect and give them the same message “sign-in is required”.
my router setup is basic and I’m not enable HotSpot
btw: this issue is suddenly happened (star yesterday), before that it was working fine without any problem at all.
I have also reset-configuration twice time but still no successful
below my wireless setup
Is there anything need to configure it on RB951G-2HnD
Do you have hotspot or not? This usually is asked with hotspot setups. So what is your hotspot config ?
no i have not enable the hotspot
setup pic shows that
Somewhere on your network, you have a hotspot server. Since you have a bridge, this would cause the issue you have.
I was expected this thing as well but i have disabled all ether ports except WAN port which is connect to my DSL Router (Cisco) with static IP
and still face same issue
I’m really began resent from this device
