i have had issues with the wireless interface on the above, my clients who keep disconnecting but when i downgraded to 4.10 it came back well. looks like a bug or something still has to be worked on.
some settings could need adjustment. you should post the disconnection debug logs from both the AP and the clients.
Which adjustments need to be made that we are not aware of? At least when an upgrade is developed notification should be placed, that after an upgrade the following need to be adjusted so that we make the adjustments after the upgrade. the logs am getting are disconnecting and connecting from the logs
George Midia
will avail the same later after i reinstall the 5.0rc1 version again. i already did a downgrade to 4.10
Did you downgrade the AP or the CPE’s? Or both?
AP only as that is what brought the issues after the upgrade
Hi gents -
I’m having similar wireless issues with 5.0rc1 on a RB433UAH and one R52Hn with two antennas connected. I’m running 2Ghz b/g/n 802.11.
Clients spend more time unable to send packets than able to - 56% loss over a ping lasting 3 hours.
Wireless debug has been enabled but the dropouts aren’t always logged - when they are, they appear to be logged as group kex timeouts.
Further details pasted below. If support need a supout or any further information, just let me know ![]()
/log pr
15:37:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
15:37:13 wireless,info wlan: data from unknown device 00:25:00:4C:AC:29, sent deauth
15:37:23 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
15:37:23 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
15:37:23 wireless,info 00:25:00:4C:AC:29@wlan: connected
15:47:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
15:47:18 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
15:47:18 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
15:47:18 wireless,info 00:25:00:4C:AC:29@wlan: connected
15:54:12 system,info,account user dave logged out via ssh
15:57:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
15:57:13 wireless,info wlan: data from unknown device 00:25:00:4C:AC:29, sent deauth
15:57:18 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
15:57:18 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
15:57:18 wireless,info 00:25:00:4C:AC:29@wlan: connected
16:03:25 system,info,account user dave logged out via ssh
16:05:58 system,info,account user dave logged out via ssh
16:07:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
16:07:13 wireless,info wlan: data from unknown device 00:25:00:4C:AC:29, sent deauth
16:07:18 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
16:07:18 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
16:07:18 wireless,info 00:25:00:4C:AC:29@wlan: connected
16:47:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
16:47:13 wireless,info wlan: data from unknown device 00:25:00:4C:AC:29, sent deauth
16:47:18 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
16:47:18 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
16:47:18 wireless,info 00:25:00:4C:AC:29@wlan: connected
16:57:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
16:57:13 wireless,info wlan: data from unknown device 00:25:00:4C:AC:29, sent deauth
16:57:18 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
16:57:18 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
16:57:18 wireless,info 00:25:00:4C:AC:29@wlan: connected
17:07:13 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, group key exchange timeout
17:07:18 wireless,debug wlan: 00:25:00:4C:AC:29 attempts to associate
17:07:18 wireless,debug wlan: 00:25:00:4C:AC:29 not in local ACL, by default accept
17:07:18 wireless,info 00:25:00:4C:AC:29@wlan: connected
17:07:25 dhcp,info dhcp-slash27 deassigned 81.187.90.183 from 00:25:00:4C:AC:29
17:07:42 dhcp,info dhcp-slash27 assigned 81.187.90.183 to 00:25:00:4C:AC:29
17:21:45 system,info,account user dave logged in via ssh
17:25:52 wireless,info 00:25:00:4C:AC:29@wlan: disconnected, extensive data loss
17:50:52 system,info,account user dave logged in via ssh
/interface wireless print:
[dave@dave-rb433uah] > /int wi pr
0 name="wlan" mtu=1500 mac-address=00:0C:42:64:F9:C8 arp=enabled interface-type=Atheros 11N mode=ap-bridge ssid="hello"
frequency=2412 band=2ghz-b/g/n channel-width=20mhz scan-list=default wireless-protocol=802.11 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=dave-sp compression=no
/interface wireless security-profiles print
[dave@dave-rb433uah] > /int wi sec pr det
0 name="default" mode=dynamic-keys authentication-types=wpa-psk unicast-ciphers=tkip group-ciphers=tkip wpa-pre-shared-key="PASSWORDHERE"
wpa2-pre-shared-key="PASSWORDHWERE" supplicant-identity="MikroTik" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none
static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none
static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no
radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
radius-mac-caching=disabled group-key-update=1h management-protection=disabled management-protection-key=""
1 name="dave-sp" mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk unicast-ciphers=tkip,aes-ccm group-ciphers=tkip,aes-ccm
wpa-pre-shared-key="PASSWORDHERE" wpa2-pre-shared-key="PASSWORDHERE" supplicant-identity="" tls-mode=no-certificates tls-certificate=none
radius-mac-caching=disabled group-key-update=10m management-protection=allowed management-protection-key=""
I am having exactly the same issue with RB493G+R52Hn v4.16. Client is MacBook Pro.
Is there something I am missing (I am new with RouterOS) or this is a hardware problem?
Thank you.
There’s a problem between Broadcom chipset Apple machines (you can check in the output of “system_profiler”) and Mikrotik 802.11n. This is fixed in 5.0rc9, but that is of course not a stable version yet.
don’t use TKIP for N. Use AES.
Broadcom N Mac users shoudl be able to connect to Mikrotik AP fine in RouterOS v5.0rc10
thank you for replies.
Yes - I am using TKIP. Going to try using AES this evening. Will let you know about results.
sorry for long silent.
OK. I have tried to use AES instead of TKIP. Maybe I have done something wrong, but it was even worse.
This is log snippets when using TKIP:
0 name="WLAN" mtu=1500 mac-address=00:0C:42:65:92:D7 arp=enabled interface-type=Atheros 11N mode=ap-bridge
ssid="eMeRnet" frequency=2412 band=2ghz-b/g/n scan-list=default wds-mode=disabled wds-default-bridge=none
default-client-tx-limit=0 hide-ssid=no security-profile=WLAN WPA2 123 compression=no
0 name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key=""
supplicant-identity="MikroTik" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0=""
static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0
static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no
interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-mac-caching=disabled group-key-update=5m
1 name="WLAN WPA2 123" mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk unicast-ciphers=tkip group-ciphers=tkip wpa-pre-shared-key="<<SECRET PASS :)>>"
wpa2-pre-shared-key="<<SECRET PASS AGAIN:)>>" supplicant-identity="" tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0=""
And this produces:
feb/22 23:57:59 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
feb/22 23:57:59 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
feb/22 23:57:59 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
feb/22 23:58:07 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving
(8)
00:02:48 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
00:02:48 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
00:02:49 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
00:02:55 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:02:55 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
00:02:55 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
00:02:58 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, received disassoc: class 3 frame received (7)
00:03:02 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:03:02 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
00:03:02 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
00:03:05 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, received disassoc: class 3 frame received (7)
00:03:08 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:03:08 wireless,debug WLAN: reject 00:1F:5B:C6:77:57, banned (last failure - received disassoc: class 3 fram
e received (7))
00:03:09 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
00:03:15 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:03:15 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
00:03:15 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
00:03:20 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, unicast key exchange timeout
00:03:21 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
00:03:27 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:03:27 wireless,debug WLAN: reject 00:1F:5B:C6:77:57, banned (last failure - unicast key exchange timeout)
00:03:37 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:03:37 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
00:03:37 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
00:05:37 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:05:37 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:05:37 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:05:46 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:06:26 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:06:26 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:06:26 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:06:33 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:10:05 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:10:05 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:10:05 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:10:13 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:19:39 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:19:39 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:19:39 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:19:51 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:20:31 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:20:31 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:20:31 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:20:37 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:21:24 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:21:24 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:21:24 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:21:31 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:22:42 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:22:42 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:22:42 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:22:51 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:28:04 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:28:04 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:28:04 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:28:15 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:32:35 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:32:35 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:32:35 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:32:42 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:33:48 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:33:48 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:33:48 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:33:55 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:35:41 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:35:41 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:35:41 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:37:23 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
00:42:48 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
00:42:48 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
00:42:55 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:42:55 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
00:42:55 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
00:42:56 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, received disassoc: class 3 frame received (7)
00:43:02 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
00:43:02 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
00:43:02 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
00:43:32 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
00:43:32 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
00:43:32 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
00:44:02 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
01:04:40 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
01:04:47 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
01:04:47 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
01:04:47 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
01:04:53 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, extensive data loss
01:05:02 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
01:05:45 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
01:05:45 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
01:05:45 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
01:06:01 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
01:06:01 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
01:06:01 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
22:58:08 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
22:58:48 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
22:58:48 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
22:58:48 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
22:58:52 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, received deauth: class 3 frame received (7)
Changes TKIP to AES:
wpa2-pre-shared-key="" supplicant-identity="MikroTik" eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1=""
1 name="WLAN WPA2 123" mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk unicast-ciphers=aes-ccm
group-ciphers=aes-ccm wpa-pre-shared-key="<<SECRET PASS :)>>" wpa2-pre-shared-key="<<SECRET PASS AGAIN :)>>"
radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s
group-key-update=5m management-protection=allowed management-protection-key=""
Gives:
23:23:18 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
23:23:25 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
23:23:25 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
23:23:25 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
23:23:27 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
23:23:28 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
23:24:13 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
23:24:13 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
23:24:13 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
23:24:19 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
23:26:39 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
23:26:39 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
23:26:39 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
23:26:46 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
23:28:18 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
23:28:25 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
23:28:25 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
23:28:25 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
23:28:36 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
23:28:37 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
This repeats every few minutes:
Any advice would be great. Thanks.
p.s. MacBook Pro wireless interface mac address is: 00:1F:5B:C6:77:57
could you contact support and include the support output file when you use AES encryption.
Also only Macbook Pro gives that problem? What MacOS you are using and are you running the latest updates for the wireless driver? Check “About This Mac” → “More info” → “AirPort” and tell us what software driver and what hardware you have there.
Will do that later this evening or tomorrow.
Em.. Basically YES - because only MBP I am using continually. I have iPhone 4 and iPad, but they are used for short time periods only, therefore I haven’t noticed any problems.
EDIT:
Well, looks like iPhone is also affected by this (currently using TKIP):
14:59:15 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
14:59:15 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
14:59:15 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
14:59:22 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
14:59:22 wireless,info WLAN: data from unknown device CC:08:E0:76:F1:F8, sent deauth
15:03:13 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
15:03:13 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
15:03:13 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
15:05:09 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, group key exchange timeout
15:05:09 wireless,info WLAN: data from unknown device CC:08:E0:76:F1:F8, sent deauth
15:05:10 wireless,info WLAN: data from unknown device CC:08:E0:76:F1:F8, sent deauth
15:05:13 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
15:05:13 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
15:05:13 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
15:05:16 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate
15:05:16 wireless,info CC:08:E0:76:F1:F8@WLAN: reassociating
15:05:16 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, ok
15:05:16 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
15:05:16 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
15:06:17 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8)
I am using latest MacOS X: 10.6.6.
As for drivers and hardware info, I will provide that later this evening, because at the moment I am not at home.
Edited. Added log for iPhone (iPhone 4 with iOS 4.2.1)
Hi uldis! That “group key timeout”…is that handled by beacon packets? Should I add that message to the list?
For others that have not seen “the list”:
http://forum.mikrotik.com/t/log-reassociating-disconnected-ok-connected/44784/1
AP send out the group key update packet and waits 1second for the reply, if it didn’t get that, it resends the packet. This is done 5 times and after the 5th time the connection is closed with the ‘group key exchange timeout’ message.
Please try to use AES instead of Tkip and try again with the iPhone.
Just to be sure - I should check AES only? I am asking, because, if I correctly remember, it is possible to check both - TKIP and AES - in Winbox.
yes, check only AES. AES encryption is faster (done in hardware) and more secure.
OK. A little bit of news:
Information from system profiler:
Software Versions:
Menu Extra: 6.2.1 (621.1)
configd plug-in: 6.2.3 (623.1)
System Profiler: 6.0 (600.9)
Network Preference: 6.2.1 (621.1)
AirPort Utility: 5.5.2 (552.11)
IO80211 Family: 3.1.2 (312)
Interfaces:
en1:
Card Type: AirPort Extreme (0x14E4, 0x8C)
Firmware Version: Broadcom BCM43xx 1.0 (5.10.131.36.1)
Locale: FCC
Country Code: X0
Supported PHY Modes: 802.11 a/b/g/n
Supported Channels: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161, 165
Wake On Wireless: Supported
Status: Connected
Current Network Information:
eMeRnet:
PHY Mode: 802.11n
BSSID: 0:c:42:65:92:d7
Channel: 1
Network Type: Infrastructure
Security: WPA2 Personal
Signal / Noise: -53 dBm / -83 dBm
Transmit Rate: 5
Firstly I have updated RouterOS to ver4.17.
Changed wireless security profile encryption to the AES:
0 name=<.....>
group-ciphers=aes-ccm wpa-pre-shared-key="PASS" wpa2-pre-shared-key="PASS"
I was using iPhone (CC:08:E0:76:F1:F8) and MBP (00:1F:5B:C6:77:57) for more than 30 mins:
14:25:20 wireless,info CC:08:E0:76:F1:F8@WLAN: connected // unlocked iPhone
14:25:20 dhcp,info dhcp1 deassigned 192.168.1.252 from CC:08:E0:76:F1:F8
14:25:24 dhcp,info dhcp1 assigned 192.168.1.252 to CC:08:E0:76:F1:F8
14:26:59 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate // turned on MBP
14:26:59 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:26:59 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:30:02 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, extensive data loss
14:30:04 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
14:30:11 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
14:30:11 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:30:11 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:30:18 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
14:30:19 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
14:30:27 system,info,account user admin logged in via winbox
14:32:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
14:32:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
14:32:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:32:16 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:32:19 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
14:32:20 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
14:37:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
14:37:09 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
14:37:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
14:37:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:37:16 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:37:20 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
14:37:21 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
14:42:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
14:42:09 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
14:42:10 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
14:42:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
14:42:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:42:16 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:42:21 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
14:42:22 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
14:47:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
14:47:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
14:47:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:47:16 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:47:20 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
14:47:21 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
14:48:33 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, extensive data loss
14:48:43 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
14:48:43 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
14:48:43 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
14:48:52 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
14:48:53 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
15:00:23 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, received disassoc: sending station leaving (8) // rebooted MBP
15:03:29 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate // windows booted
15:03:29 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
15:03:29 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
15:03:29 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
15:03:29 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
15:11:07 system,error,critical login failure for user root from 174.123.78.37 via ssh
15:11:09 system,error,critical login failure for user root from 174.123.78.37 via ssh
15:11:12 system,error,critical login failure for user root from 174.123.78.37 via ssh
15:11:14 system,error,critical login failure for user root from 174.123.78.37 via ssh
15:13:12 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, extensive data loss // windows shutdowned
15:14:01 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate // Mac OS X booted
15:14:01 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
15:14:01 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
15:18:30 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8) // iPhone went to sleep
15:18:43 wireless,debug WLAN: CC:08:E0:76:F1:F8 attempts to associate // iPhone unlocked again
15:18:43 wireless,debug WLAN: CC:08:E0:76:F1:F8 not in local ACL, by default accept
15:18:43 wireless,info CC:08:E0:76:F1:F8@WLAN: connected
15:19:05 wireless,info CC:08:E0:76:F1:F8@WLAN: disconnected, received disassoc: sending station leaving (8) // iPhone locked
15:22:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
15:22:10 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
15:22:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
15:22:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
15:22:16 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
15:22:26 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
15:22:27 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
15:27:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
15:27:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
15:27:16 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
15:27:16 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
15:27:26 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
15:27:27 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
15:27:51 system,info,account user admin logged in from 192.168.1.11 via ssh
15:28:23 system,info,account user admin logged in via local
15:30:52 system,info,account user admin logged out from 84.15.169.216 via ssh
15:32:09 wireless,info 00:1F:5B:C6:77:57@WLAN: disconnected, group key exchange timeout
15:32:10 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
15:32:11 wireless,info WLAN: data from unknown device 00:1F:5B:C6:77:57, sent deauth
15:32:17 wireless,debug WLAN: 00:1F:5B:C6:77:57 attempts to associate
15:32:17 wireless,debug WLAN: 00:1F:5B:C6:77:57 not in local ACL, by default accept
15:32:17 wireless,info 00:1F:5B:C6:77:57@WLAN: connected
15:32:28 dhcp,info dhcp1 deassigned 192.168.1.11 from 00:1F:5B:C6:77:57
15:32:29 dhcp,info dhcp1 assigned 192.168.1.11 to 00:1F:5B:C6:77:57
As you can see, iPhone is not mentioned in the log (except for unlocking, sleeping, and locking). I was watching video through youtube, Airvideo (takes video from remote streaming server) and CrystalTV (internet tv). Also checked mail, browsed web. Everything was ok.
On the Mac OS connection was not stable. On Windows (according to the log) it wasn’t disconnected, but speed was VERY poor. On OSX when using TKIP I am able to use internet, but it drops periodically. With AES, practically unusable. Very often even pinging router is timed out.
