Anyone else seeing this issue?
RB/333 with 3 R52H or 3 Ubiquiti SP2, or 3 Engenius 600mw (not sure model #), only 1 active on channel 1,6, or 11 (tried them all). 7dbi omni antenna.
AP/Bridge mode, single wlan to ether1.
Single client connected, tx/rx rate starts out at 54Mbps and will stay there or slightly lower, 48/36, will get 20+mbit/sec transfers, works great.
Every minute the modulation goes down to as low as 2Mbps-SP, and slowly climbs back up. If change preamble to Long things work slightly better, no SP modulation.
I have disabled periodic calibration (seems to be the only thing the is set to 1 minute).
Any assistance would be appreciated, we have tried everything w/o much luck.
Thanks.
