Wireless Key
Hi people,
I use several years using your devices and I am very gratefull with us. I installed lot of hotspots in Span and in all hotspots I configure the wireless interface as an open system. Obviously, I install a SSL certificate for my login page because I redirect to my login web server to insert the user/passwd. The SSL certifice is un the login web server.
I think with this method I cypher only the authentication against my RADIUS server., but I do not cypher the later comunicactions. And this the goal that I follow.
How can I get this??
If I put the hotspot DN loginuser.akiwifi.es in all my hotspots (>500) and buy a SSL certificate for this domain. And later I install it in my hotspots. Do I cipher all communications between the AP MT and a client or only cipher the authentication against RADIUS ?
