Report any bugs you can find and we will try to improve it.
Of course, this is a synthetic calculator (theoretic). Real life has things like interference, weather and other factors that will reduce possible distances.
A known bug, that in Chrome, the elevation graph doesn’t support hover over specific hill. Currently does work in Firefox/Safari.
The calculator does take into consideration the elevation, the fresnel zone, the earth curvature. It currently does not tell you exactly how big your towers need to be, but it will tell you that you need a big tower, if there is difficult elevation, or earth curvature that disturbs the 60% fresnel zone.
How to use:
Choose the frequency band
Choose the minimum required data rate
Choose the products from the list
Move the map markers to the desired area.
Click “calculate link”
Observe the elevation graph. Move your mouse to the hills, so see which ones might cause issues. Drag over the elevation graph to select bigger areas, to identify them.
Adjust products or markers until the result is “Reliable” and doesn’t mention that “Very high tower needed”
Please comment here if you find problems, mistakes or other issues.
If you will let the calculator load the value for all the available input/drop-down etc. boxes from the URL, then i can also add direct links on all the individual product pages on my distributor site
But if you can’t put the exact gps coordinates for the Tx Rx points, and tower weight (isn’t same if I have 2m or 5m tower) is only to play.
Another small think, doesn’t fit the configuration panel and the “Reset” “Calculate link” button in the same screen, need to scroll.
Is my 1600x900 monitor resolution to small, I don’ think all peaple use fullhd resolution. Maybe you can decrease a little that config panel window.
Sorry for remaks. It’s an awaited tool, thanks for it.
Cannot access the map behind the calculator to set the locations in Mozilla on android phone. The speed slider should allow only possible values for the set pair of devices in selected band.
Maybe I’m using this wrong, but it appears to me that if I select a product the calculator fills in the maximum power of that product, and then doesn’t let me edit that figure if the maximum power is more than I can use legally in my area.
Nice tool. Will be good if one can simply enter coordinates of the TX and RX location as an option to just Moving the map markers to the desired area.
Also, the ability to export the report out in jpg/pdf or any other usable format will be fantastic.
