Wireless link going down
Hello everyone, i need some help here… I have a 30km link, on one end there is a RB532 with a XR5 card, and the other is a RB133, with another XR5.
The first time we setup the link, everything was Ok, we reached -57 of signal strenght, but now it keeps disconnecting.
We have two solid parabolic dish antennas, 29 dBi…
I have some logs with wireless, debug enabled in both sites.
The log on the remote place says the following:
wlan0: must select network
wlan0: no network that satisfies connect-list, by default choose with strongest signal
wlan0: failed to select network
wlan0: delaying scanning
wlan0: STA starts scanning
wlan0: STA scan over, results:
Then it shows 5 or 6 networks, none of mine, and then it starts the scanning again…
When I use the Scan tool, on winbox, on wlan0 propertys box, I’m able to see my ssid, and it shows up with -57 ~ -60 of signal…
Could it be noise?? There are many 5.8Ghz networks
Noise Floor?
CCQ?
Ack?
Configuration?
I am having an eerily similar issue, about the same distance, same cards, same boards - same symptoms.
Take a look at my thread.
We solved the problem using 5Mhz band, our troughput is only about 3Mbps now, but it is enough for us.
Our noise floor is -97dBm, SNR is ~40, overall CCQ is 89~97% now.
Our setup is a WDS.
ACK is set dynamic, and the value right now shows 68us.
The link has 3 days and 2 hours uptime after the 5Mhz band selection, before this the link was falling down every 2 or 3 minutes.
We still don’t know what was the problem on normal band setup, but we can’t investigate too much since this link is now in production with client traffic.
