Please what can i do to still be in busness below is a list of wireless interface scan at night some time the link work well but in the afternoon it trible at first it was working well unitill recently when it all start
and a log of the link
ADDRESS SSID BAND FREQ SIG RADIO-NAME
AB 00:02:6F:23:05:84 Optimum 2.4ghz-b 2412 -63
AB R 00:11:95:E7:1D:0F cqomni 2.4ghz-b 2412 -59 001195E71D0F
ABP 00:02:2D:18:A9:C7 snipett 2.4ghz-b 2412 -75
AB 00:02:2D:5E:9E:9A Zeus 2.4ghz-b 2417 -76
AB R 00:02:6F:3F:3B:73 UNIBENWIRELESS1 2.4ghz-b 2417 -26 00026F3F3B73
ABP 00:0D:F5:10:3E:2C PPRH2 2.4ghz-b 2422 -75
AB 00:02:2D:93:88:86 Hercules 2.4ghz-b 2427 -56
ABP 00:02:2D:17:CE:F6 NATIONAL 2.4ghz-b 2427 -79
AB 00:0D:F5:10:3A:FE SurfSpot 2.4ghz-b 2447 -89
AB 00:02:2D:29:E6:37 Dercworld 2.4ghz-b 2447 -76
AB 00:02:2D:27:70:51 cqgrid 2.4ghz-b 2447 -79
AB 00:02:2D:75:C1:95 surfcom_net 2.4ghz-b 2452 -76
AB 00:05:5D:EE:69:4D mquest 2.4ghz-b 2457 -86
ABP 00:02:2D:C0:14:E5 snipett 2.4ghz-b 2457 -85
AB 00:02:2D:5E:85:52 presokap 2.4ghz-b 2457 -86
AB R 00:13:46:94:B4:3D mquest 2.4ghz-b 2457 -81 00134694B43D
AB R 00:02:6F:3F:3B:72 UNIBENWIRELESS3 2.4ghz-b 2457 -37 R3
ABP 00:0D:F5:10:3F:E7 XTS 2.4ghz-b 2457 -84
AB 00:60:1D:1F:01:BD Express7 2.4ghz-b 2462 -55
AB 00:30:4F:36:36:74 OTOSAT 2 2.4ghz-b 2462 -78
AB 00:02:2D:4A:10:F1 SurfSpot3 2.4ghz-b 2432 -77
01:00:34 wireless,info wlan2: data from unknown device 00:02:6F:37:B1:40,
sent deauth
01:00:34 wireless,info wlan3: data from unknown device 00:02:6F:36:B3:35,
sent deauth
01:00:35 wireless,info 00:02:6F:37:61:0F@wlan2: connected
01:00:35 wireless,info 00:02:6F:3A:D8:1A@wlan2: connected
01:00:36 wireless,info 00:02:6F:3F:3B:71@wlan1: connected
01:00:36 wireless,info 00:02:6F:37:B1:26@wlan2: connected
01:00:36 wireless,info 00:02:6F:37:B1:40@wlan2: connected
01:00:37 wireless,info 00:02:6F:37:B1:26@wlan2: disconnected, reassociating
01:00:37 wireless,info 00:02:6F:37:B1:26@wlan2: connected
01:00:37 wireless,info 00:02:6F:37:B1:11@wlan2: connected
01:00:37 wireless,info 00:02:6F:3A:D8:1A@wlan2: disconnected, reassociating
01:00:37 wireless,info 00:02:6F:3A:D8:1A@wlan2: connected
01:00:37 wireless,info 00:02:6F:37:B1:40@wlan2: disconnected, reassociating
01:00:37 wireless,info 00:02:6F:37:B1:40@wlan2: connected
01:01:10 wireless,info 00:02:6F:37:B1:11@wlan2: disconnected, extensive data
loss
01:01:26 wireless,info 00:02:6F:37:61:0F@wlan2: disconnected, extensive data
loss
01:02:12 wireless,info 00:02:6F:37:B1:26@wlan2: disconnected, extensive data
loss
01:02:47 wireless,info 00:02:6F:37:B1:11@wl
what kind of cpe er you connecting? how many?
how about using more radios for ap and sectorized antennas?
try routing instead of bridging (if you do bridging)
I use router board 532 with 120 degree sectoral anternal, i do brideing with each the interface wlan1 to ether1,wlan2 to ether2 and wlan3 to ether3 i use Senao radio 200miliwait
try to use routing instead of bridging (at least make an attempt).
reduce max speeds.
i will do that and give u feed back (note the senao radio there are about 40 system behind then and we use DHCP b/c it a school
and you bridge their network onto yours?
remember to remove the ap’s wireless interface from the bridge when you try it. also if you use virtual-ap’s on that interface then remove those from bridge as well.
