Wireless link that supports jumbo frames without packet frag
We need to create a wireless link between two close locations with high throughput and with the support for Jumbo Frames and without packet fragmentation? This is the link for the firewall cluster and without the fulfillment of these conditions we not have approval for implementation. The budget is large. We are thinking about the Dual NStream, NV2 protocol maybe … Do you have any ideas, suggestions?
You dont give enough information. What size are these frames? “jumbo” MTU can mean anything from 1500-10000.
With mikrotik hardware, you are going to have a max MTU of about 4076 on an ethernet interface (not all devices!). Then you need to have large frame support on the wireless interface. The R52Hn is 2290. That effectively makes your max frame size 2290.
I’m not sure what the jumbo frames are for in your case. Passing VLANs? some sort of encapsulation? iSCSI?
