wireless link throughput doesn't match tx/rx rate
Hi
I got a 10Km wireless link using RB411AH and 30dbi antenna . my best signal after working around the configuration is around -60dbm and the tx/rx rate shown in registration is like 48Mbps .
I know the signal is not very good specially considering the low CCQ but I want to know if this case is normal and if yes what is the actual reason .
although radio show around 48Mbps tx/rx rate my actual throughput is around 6Mbps ( around 700KBps when copying files ) and not getting any better .
Hello.
Try another channel. It looks like the one you are using is occupied
also you have bad signal. one chain is realy low. Chek pigtails
