Wireless lock????
Well I am running wireless networks using mikrotik and I am wondering is there any chance to block my client ap form the mikrotik.It has authentication and is added to the access list.I try to remove the ap from the access list but it didn’t work?Any suggestions?
Greetings!
When you entered the MAC in the access list, did you remember to set authentication=no? The default is ‘yes’.
Well if i set it “NO” what I have to do next to block it
You should not need to do anything else. That should block that mac address. Is it not blocking the mac even with authentication=no?
ADD: If the mac is already authenticated, it may not deauth the mac. You may need to manually deauth it or reboot the router.
10x It works.
You have a beer from me :slight_smile:
