Hi all,
i try to make a mesh network configuring 4 nodes. Here is my configuartion:
Setup mesh interface
Mesh1 / Mesh2 / Mesh3 / Mesh4 /…
add mesh interface
/interface mesh
add name="Mesh-interface"
assign ports to the mesh interface
/interface mesh port
add interface=wlan1 mesh="Mesh-interface"
add interface=ether1 mesh="Mesh-interface"
Setup IP on the Mesh-Nodes
Mesh1
add ip to the mesh interface
add address=192.168.0.1/24 interface="Mesh-interface" comment=”Mesh addresses”
Mesh2
add address=192.168.0.2/24 interface="Mesh-interface" comment=”Mesh addresses”
Mesh3
add address=192.168.0.3/24 interface="Mesh-interface" comment=”Mesh addresses”
Mesh4
add address=192.168.0.4/24 interface="Mesh-interface" comment=”Mesh addresses”
Setup wireless interface
dynamic-mesh creates WDS entries for you
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile1 supplicant-identity="" wpa-pre-shared-key=mykey wpa2-pre-shared-key=mykey
/interface wireless
set [ find default-name=wlan1 ] disabled=no l2mtu=2290 mode=ap-bridge security-profile=profile1 ssid=Mesh-Network tx-power=3 tx-power-mode=all-rates-fixed wds-default-bridge=Mesh-interface wds-mode=dynamic-mesh
Tuning wireless settings
ban equipment with low signal strength (<-100)
/interface wireless access-list
add signal-range=-100..120
Setup default route
add distance=1 gateway=192.168.0.254
Setup time synchronization
/system clock
set time-zone-autodetect=no time-zone-name=Australia/Hobart
Setup NTP Client
Mesh1 is getting ntp time from specific equipment
/system ntp client
set enabled=yes primary-ntp=192.168.0.10
Setup NTP Server
/system ntp server
set broadcast=yes broadcast-addresses=192.168.0.19 enabled=yes manycast=no
Mesh2 / Mesh3 / Mesh4 /…is getting ntp time from Mesh 1
/system ntp client
set enabled=yes primary-ntp=192.168.0.19
Create user for monitoring purpose
/user group
add name=monitoring policy=winbox,read comment="Group for monitoring purpose"
/user
add comment="system default user" group=full name=admin
/user
add name=dude password="dude" group=monitoring address=192.168.0.1/32 comment="User for Dude monitoring"
Make Leds as
/system leds
add interface=wlan1 leds=led1,led2,led3,led4,led5 type=wireless-status
add interface=ether1 leds=user-led type=interface-activity
Setup DHCP server
Mesh1
#addresses for equipment 192.168.0.20-192.168.0.250;
add name=dhcp-ip-pool ranges=192.168.0.20-192.168.0.250
add address-pool= dhcp-ip-pool always-broadcast=yes disabled=no interface=
"Mesh-interface" name= dhcp-server
add address=192.168.0.0/24 dns-server=192.168.0.253 gateway=192.168.0.254
Setup DHCP Client
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether1
Setup address list on firewall
/ip firewall address-list
add address=192.168.0.1 comment=Mesh1 disabled=no list= Mesh-Nodes
add address=192.168.0.2 comment=Mesh2 disabled=no list= Mesh-Nodes
add address=192.168.0.3 comment=Mesh3 disabled=no list= Mesh-Nodes
add address=192.168.0.4 comment=Mesh4 disabled=no list= Mesh-Nodes
Other Equipment - dynamic via DHCP
set allow-remote-requests=yes servers=192.168.0.253
/ip dns static
add address=192.168.0.253 name="DNS Mesh Network"
Thank you!
