Wireless Modulation OID for Zabbix
I’m not getting a value to wireless modulation in version 6.38.5 (BaseBox 5). The value for the tx-rate and rx-rate OID are 0, even the radio is operational at MCS 11 (120mbps/120mbps).
Suggestions?
:confused:
Same result here, using hAP lite. Tested on 6.38.5 and 6.39rc80.
E-mail to > support@mikrotik.com> , please.
Hello Tomasi,
Correcting the post.. to get the values of Tx and Rx Rates, you need to lookup in Registration Table.
/interface wireless registration-table print oid
And use the Tx and/or Rx Rates oid. @sergejs helped me on this by e-mail support.
Thank you,
Now it’s working:
