u try to uncheck the default authenticate, then add you client mac address to the access list one by one.
you should able to figure out who are the one creating a trouble then just reject it…
From one machine it was flooding? But currently I am using Wireless AP [ Omnitik] and then Other p2mp machines connecting to it. The other CPEs- are in Bridge mode. I want them in station /router mode.
So I can prevent such flooding.
CPE [172.168.11.9] ----->Wireless AP[172.168.11.4]—> Connected to Main router[ 202.x.x.x.]
What should be the configuration for the same? In AP and in CPE/Station mode?
I was going to use PPPoE as well but decided not to for that reason. All a user needs to do is plug a switch or two in to their client bridge and you can easily end up with a broadcast storm.
