wireless network mesh for private and hotspot
Hi, i am new for the mesh and need some help .
I need to set up 2 Wifi network one for private nad one for hotspot .
Router: RBD52G-5HacD2HnD ( hap AC ) with working hotspot on separate bridge
AP: RBwAPG-5HacT2HnD
AP2: RBwAP2nDr2
The first AP have 2 wlan interface and so i can configure the 5G for WDS with the router but the second AP have just 1wlan interface and i dont know if there would work the virtual interface or could i use just the LAN from the APs ?
is it possible to add wlan1 + ether1 to mesh so the router and the APs interact over lan and the user have one ssid signal ?
thx for the help
What is mesh in your opinion?
Cable is always the preferred option for your backhaul.
i need seamless roaming
Ok, seamless roaming is possible if you configure the radios correct together with access lists. It will take same tweaking, but it is doable.
And, please don’t try the wireless backhaul route because that won’t work as good as wired.
and how could i do this ? i have on the router ports switch , on the switch a lot of clients ( PCs, Cameras,etc..) i cant give the port to mash on the router.. or? i dont use vlan
right now i manage the APs over CapsMan2 and 2 bridge.
should i set on the
APs: mesh ports, ehter1 + wlan1
router: after i set up the capsman set the cap1 to mesh port ? would it work?
No one can help by mesh? i would pay for it ! really bad that i cant find any manual or video on youtube about : how to set up mesh by Mikrotik
Use Musk’s Starlink Project, haha
