The RB 1200 run a dhcp server and runs the nat masquerade for private-> public address translation.
The RB751 is setup just as a simple switch (all ports are bridges including the wlan) /wireless ap, No routing or anything special here.
The problem. When i connect with a wired pc it gets its dhcp assigned ip information correctly. Pc connecting wirelessly can setup static ip information and connect successfully. However, if you connect via wireless and try to use the dhcp, it’ll assign you an ip out of the pool perfectly fine, it just will not assign the gateway ip. I’ve looked at the RB1200 where the dhcp server is setup and its got the gateway info entered, and if you connect with a wired pc it WILL assign the gateway ip perfectly fine.
Not sure what to think by this point. Any help would be greatly appreciated.
751 doesn’t have some dhcp server running on bridge interface by chance? Try disabling dhcp pkg in 751 if you have one. Just to be sure. Otherwise, indeed this sounds strange..
Hmm, well after a day passed, i just noticed the wired pc isn’t getting a gateway assigned either. What would cause it to not assign a gateway even tho its entered in the dhcp server network tab.
