Version number; : ROS 7.0beta3
Router’s model; : mAP Lite
Not working wireless, It disconnects constantly. There is no parameter that stabilizes the connection.
@MikroTik] > /system/resource/pr
uptime: 36m4s
version: 7.0beta3 (development)
build-time: Oct/22/2019 09:34:17
factory-software: 6.36
free-memory: 28.3MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 650MHz
cpu-load: 11%
free-hdd-space: 4780.0KiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 37
write-sect-total: 19538
bad-blocks: 0%
architecture-name: mipsbe
board-name: mAP lite
platform: MikroTik
Log:
02:46:32 wireless,info D8:68:C3:44:3F:89@wlan1 established connection on 2462000, SSID TocToc
02:46:45 dhcp,critical,error dhcp-client on wlan1 lost IP address 10.4.1.19 - received NAK from dhcp server 192.168.43.1
02:46:45 system,info
02:46:48 dhcp,info dhcp-client on wlan1 got IP address 192.168.43.75
02:46:48 system,info
02:47:38 wireless,info D8:68:C3:44:3F:89@wlan1: lost connection, no beacons received
02:47:43 wireless,info D8:68:C3:44:3F:89@wlan1: failed to connect, on 2462/20/gn(18dBm), authentication timeout
02:47:58 wireless,info D8:68:C3:44:3F:89@wlan1: failed to connect, on 2462/20/gn(18dBm), authentication timeout
Configuration:
@MikroTik] > /export hide-sensitive
# jan/01/2002 03:17:50 by RouterOS 7.0beta3
# software id =
# model = RouterBOARD mAP L-2nD
# serial number = 73B207163703
add authentication-types=wpa-psk,wpa2-psk disable-pmkid=yes eap-methods="" group-key-update=30m mode=dynamic-keys \
name=pTOCTOC supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode ampdu-priorities=0,1,2,3,4 antenna-gain=2 \
band=2ghz-b/g/n country=spain disabled=no frequency-mode=regulatory-domain hw-protection-mode=cts-to-self \
installation=indoor radio-name=android security-profile=pTOCTOC ssid=TocToc wireless-protocol=802.11
/ip hotspot profile
add name=dhcp_pool0 ranges=10.0.0.2-10.0.0.254
add add-arp=yes address-pool=dhcp_pool0 disabled=no interface=ether1 lease-time=1d name=dhcp1
/queue tree
add limit-at=1M max-limit=2M name=uplink parent=wlan1 queue=default
add limit-at=8M max-limit=10M name=downlink parent=ether1 queue=default
add limit-at=8M max-limit=10M name=down_clients packet-mark=pk_clients parent=downlink priority=1 queue=default
add limit-at=1M max-limit=2M name=up_clients packet-mark=pk_clients parent=uplink priority=1 queue=default
/user group
add name=ftp_users policy="ftp,test,!local,!telnet,!ssh,!reboot,!read,!write,!policy,!winbox,!password,!web,!sniff,!s\
ensitive,!api,!romon,!dude,!tikapp"
set enabled=yes
add address=10.0.0.1/24 interface=ether1 network=10.0.0.0
/ip dhcp-client
add dhcp-options=clientid_duid,hostname,clientid disabled=no interface=wlan1 use-peer-dns=no use-peer-ntp=no
add address=10.0.0.0/24 dns-server=1.1.1.1 gateway=10.0.0.1
set servers=1.1.1.1
/ip firewall address-list
add address=10.0.0.0/24 list=ACL100
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=conn_clients passthrough=yes src-address-list=ACL100
add action=mark-packet chain=prerouting connection-mark=conn_clients new-packet-mark=pk_clients passthrough=no
add action=masquerade chain=srcnat out-interface=wlan1
#error exporting /ipv6/route/rule
#error exporting /routing/policy/selection
/system clock
set time-zone-name=Europe/Madrid
/system package update
set channel=development
