Wireless P2P in Wind Turbines
Hi friends we have a Wireless intranet project for a Wind Turbine Company.Our question is do the wind turbine blades block the signals as the turbine leafs are about 6 feet length. The maximum distance between 2 Points is 2 km. Pls friends suggest me in chosing the corresponding products and type of solution for the above scenario.
Turbine yes but blades are made from fiber plastic!? so it shouldn’t be a problem I guess.
If the blades are made of polyester. NO
Metal blades can constitute a problem
Maybe create a trial application and test out
