Wireless PEAP
Hello. I’m trying to setup 30 of the Groove 52HPN devices. We have an Aerohive infrastructure that utilizes RADIUS proxy back to a Microsoft NPS (PEAP). Do these devices support this setup? I’m finding previous posts stating this is not available, but most of those are 2-3 years old. Can anyone point me to the documentation specifically for this configuration?
Thanks.
It is supported, here you can look in this topic newer messages:
http://forum.mikrotik.com/t/peap-mschapv2/102071/1
You need to update to the latest stable version to have this feature in client mode. Do that first.
Then, you can configure it in the Wireless Security Profile that you use with your Wireless client config.
As far as I know, it has not yet been added to the documentation (attention point for MikroTik: when some feature is
implemented, updating the manual for that feature should be part of the process…)
Set “authentication types” to WPA2-EAP
Set “EAP methods” to “PEAP” (new, undocumented setting)
Set “TLS mode” to “don’t verify certificate” (at least at first)
Set “TLS certificate” to “none” (at least at first)
Enter the “anonymous identity” into the “Supplicant identity” field.
Enter the “username” into the “MSCHAPv2 Username” field.
Enter the “password” into the “MSCHAPv2 Password” field.
Then it should basically work.
Could you please tell me how will be the corresponding or important wireless settings in user manager that will work with the above setting.
