I have a test setup which has a signal of -54dB it runs on both sides on a intel platform P4 2.8Ghz (775 socket) and P3 1Ghz (serverworks chipset) it uses both an MT 5211 radio that runs on 2.8.24.
But my troughput is low for it must can be. On 5Ghz-turbo and 5800 it stays on 43mbit, and when i enable nstreme on de systems i had only 23 mbit of data stream trough the router. This problem i had in bridged mode en in routed mode. My CPU does not rise to the 100% but max to 60% on the P3
Interference on the other band in Turbo?
Turbo works by bonding 2x 20MHz bands to 40MHz using adjacent channels.
Suggest trying adjacent channels in non-Turbo to see throughput, then try Turbo when they give good throughput.
Have you got any older versions of RouterOS to try?
Any other PC motherboards to try?
There are some “BIOS funnies” in certain boards, EPIA-V is a known problem with atheros/ethernet poor performance
The 5211 isn’t the problem IMHO, we’ve used those in extensive tests
Johan, I’ve had similar problems as you’ve had. Tested at 2M and throughput was around 45-50mbps. Similar type of setup with 2 Intel-based servers just doing a b/w test with the newest betas…
So I guess this doesn’t apply to his problems. My best guess is still the distance between the nodes. I tried again yesterday: Bandwidth between my two 5GHz nodes fell dramatically as I moved them closer to each other (parabolic dishes).
I’ve test it @10m on a Nforce3 AMD64 and intel915 P4, with result 43 Mbit.
PS. I’ve got a 4 Minipci adapter from mikrotik but when i try to connect to an another system it won’t connect in a 1 slot mini-pci adapter it runs well.
