Wireless Performance
Hi
I have problem
I want to Cut wireless users ( 2.4Ghz ) to 640/640kbit/s ( per station ) and set priority as nonP2P first and P2P last .
I hope someone will help me soon …
Lokacz
This has been discussed many times please read the manual and search the forum. What you need to do is easy on MikroTik Router OS - I should work for MT! :wink:
Start here :slight_smile:
http://www.mikrotik.com/docs/ros/2.9/root/queue
Then go to winbox and start playing with queue’s :slight_smile:
