wireless problem in 3.0xx, low thruput, high latency
Hi, help me, i have RB532 and CM9 card as AP and clinet Ovislink WL-5460AP. In version 2.9.x its all great, high thruput and low latency. If upgrade to 3.0xx, all is bad. Thruput abou 700kbps and ping about 300 - 1500ms :frowning: . The same problem with NTB HP compaq. I testing the new RB333 and its suport only 3.0xx and problem is the same, but no way to 2.9.xx :frowning: . Siganl is good -60dB.
Pleas help me, is some bug in ROS or only configuratin problem?
Thanx
Some screenshot, upset in registration table, and normal latenci in idle, no trafic. :frowning:
which version of 3.0 are you using? I believe I read they fixed that in the latest RC.
Sam
3.0rc4 on RB333
umm.. how does your wireless client have a mac address of 00:00:00:00:00?
but, my clinet not have 00:00:00:00:… Have real MAC 00:4F:62:… , but in registration table is wrong, and also interface “unknown”.
please make the support output file and send it to support@mikrotik.com
ok, i send supout and mor info, thanx
