Wireless problem in phone
Hello, when mi phone samsung galaxy s4 connects to wifi, the screen of my phone is black and the phone locked and is not responding. Also the battery of the phone is quickly consumed. Only happens with samsung phones (two phones samsung), ios and other work correctly. What is the problem?.
Regards.
Hi.
Did you log mikotik wireless interface?
Hello, can you explain more please??
The mac E8:50:8B:B1:69:67 is the phone, when this connect with mikrotik locked and not responding.
If your wifi problem is with a MikroTik Router. It is necessary to watch system log to check what’s happend
Do you have some firewall rules in your router?
Please make complete export of your configuration
There is nothing wear in configuration file.
Have you try to connect your cell phone in another brand or MikroTik access point? .
The problem could be your phone
Yes, the phone in my house works perfectly with my wifi.
Try a different frequency. 2472 may not be supported in your phone.
ok, what frequency is appropriate?
Depends on your environment. Just try any non-EU channel for testing eg 2412.
