hi all
i just want to say ,
as i upgrade mikrotik to v 3.9 all my p2p links got worse .
link unstable , bandwidth low , cant use custom frequency on some links with XR5 , and on links with
Cm9 AR 5213 , cant use nstream , just cant enable nstream
about that custom frequency i contact MT support , and they say
to use custom-frequency feature set in your wirless card settings:
frequency-mode=superchannel
regulatory-domain=no_country_set
but i already know that… so …
and still card cant connect .
to add..
links on v3.7 works well , nstream ok , custom frequency ok.
as can i see more ppl have problems on wireless …
Anyone else have feedback either way on this topic. I was going to deploy some new rb411s with 3.9 but I don’t need to cause myself unnecessary pain and suffering.
Thanks,
Scott
Dunno…
We upgraded all our units to 3.9 and it all seems rock solid…!!
Everything working as normal…
I haven’t paid THAT much attention to it all (because it’s all working) - one thing I did notice is the menu highlight button doesn’t pop when to mouse is moved over it… but hey! - if that’s all it is I can live with it.
Nope - works well for me..!! Even the CPU Load “jump around” indicator seems fixed.
Just my .02 cents worth.
Tanker
the same problem as i have seen.
i could only solve the problem on 3.x PTP with n-streme.
see my post:
viewtopic.php?f=7&t=26260
