Wireless problem see this!!!
I have a problem with my wireless. at first i was using v2.8.28 and this problem was shown , i upgraded to 2.9.6 and i think i have the same problem , Plz see this screenshot of one of my AP and post your comments what the problem can be!
Well, it’s a picture :smiley:
Come on dude, how can we help just by lookin’ da picture?!
Does your clients get disconnected or what.
Fill us with more information’s dude :wink:
What is your problem :unamused: ?
I suggest you to use ‘Torch’ tool for real-traffic monitoring.
nope, the clients doesn’t disconnect but when betwen the traffic lines are spaces like in the picture , the clients get TIME OUT , maybe 2 or 3 timeout’s
Turn of default forwarding for each user in wireless access list…
thats now working man :cry:
anyone has an idea what the problem can be..
i’m using bridge connections the wireless accesspoint router has no firewall rules , no simple queues , just 3 prismII cards runing in ap mode..
On what freq are those cards working?
Please post your wireless configuration…
Here’s my config…
interface wireless> print
 0  R name="Wlan" mtu=1500 mac-address=00:02:6F:xx:xx:xx arp=enabled disable-running-check=no interface-type=Prism
      prism-cardtype=200mW radio-name="00026F365B9C" mode=ap-bridge ssid="wlanap" area="" frequency-mode=superchannel
      country=no_country_set antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default rate-set=default
      supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-b=1Mbps max-station-count=2007 tx-power-mode=default
      periodic-calibration=default dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
      wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no default-forwarding=yes
      default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms preamble-mode=long compression=no allow-sharedkey=no
 1  R name="Wlan2" mtu=1500 mac-address=00:02:6F:xx:xx:xx arp=enabled disable-running-check=no interface-type=Prism
      prism-cardtype=200mW radio-name="00026F39F5F9" mode=ap-bridge ssid="wlanap2" area="" frequency-mode=superchannel
      country=no_country_set antenna-gain=0 frequency=2457 band=2.4ghz-b scan-list=default rate-set=default
      supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps max-station-count=2007
      tx-power-mode=default periodic-calibration=default dfs-mode=none antenna-mode=ant-a wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default
      disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long compression=no allow-sharedkey=no
 2  R name="wlan1" mtu=1500 mac-address=00:02:6F:xx:xx:xx arp=enabled disable-running-check=no interface-type=Prism
      prism-cardtype=200mW radio-name="00026F3691E4" mode=ap-bridge ssid="wlanap1" area="" frequency-mode=superchannel
      country=no_country_set antenna-gain=0 frequency=2412 band=2.4ghz-b scan-list=default rate-set=default
      wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no
Could scan for oter AP`s in area and post your results.
here is the scan
Flags: A - active, B - bss, P - privacy, R - routeros-network, N - nstreme
      ADDRESS           SSID    BAND       FREQ SIG RADIO-NAME
AB    00:0F:B5:xx:xx:xx SSID1    2.4ghz-b   2412 -79
AB    00:02:6F:xx:xx:xx MyWlan1 2.4ghz-b   2437 -45
AB    00:02:6F:xx:xx:xx MyWlan2 2.4ghz-b   2457 -49
AB    00:02:6F:xx:xx:xx SSID2-   2.4ghz-b   2452 -71
AB    00:0F:B5:xx:xx:xx SSID3    2.4ghz-b   2462 -83
AB    00:02:6F:xx:xx:xx SSID 4   2.4ghz-b   2422 -59
AB    00:02:6F:xx:xx:xx SSID5    2.4ghz-b   2442 -42
ABP   00:02:6F:xx:xx:xx SSID6   2.4ghz-b   2447 -60
AB    00:0F:3D:xx:xx:xx SSID7   2.4ghz-b   2412 -82
Time outs are comon in wireless. Your link is bad, too much noise, other interferences or weak signal causes this.
Try using this chanels:
  1. 2412
  2. 2427
  3. 2462
And tell me what kind of antenna are you using. 120 sector or?
i tried those channels , but it’s same:S
yes i’m using 120* sector anntenas
