Router board:800, ROS v4.13
Radio card:R52nH
Antenna:Sector 120 16dBi x 2, 5GHz (The antenna frequency range is from 5150 to 5850 MHz)
I have some questions.
1.How do i know that my antennas work?
2.How do i know that my 52Hn card work?
Trouble
When i connect my radio cards to board all is OK but in wireless interface wla1 in not active, i think need to be (R) or I’m wrong.
Tx and Rx is on 0 no reaction at all i even change radio card (i have 2 cards), when i change card there is the same problem.
I connect my both antennas to card with 5m(400) cable.I’m new to Mikrotik maybe I’m doing something wrong.
Can someone help me setup all in right way.
Thank you
Sorry for bad English…
i think your laptop wlan card doesnt know such a standart as 802.11n, and thats your problem. select AP band to 2.4Ghz b/g and i think u should be good..
Thank you…
I think so that my card don’t know anything about .11n.
And i already order 2.4GHz antenna’s now i will wait.How i can use my 5GHz antenna’s?
I can use for bridge from building to building?
yes u can use your 5Ghz antennas for point to point connection from building A to building B without any problems. 5Ghz has less interference, only u need clear LOS.
