We played with wireless calculators a little, and came up with these tables.
The tables are based on perfect conditions - interference, weather, alignment will affect your real life results.
The data was taken from the product specifications, and entered into wireless calculators.
The table shows the max distance if you want to get max data rate at 802.11ac or 802.11n, and the max distance if you don’t care about speed. We used -70 as the signal for the high distance result, if lower signal is acceptable, you will get bigger distances.
For sure it will be very useful for people in order to select the proper equipment!
Cannot spot any mistakes (apart from obious ) and calculated results are in line with real life experience after you factor in a reasonable real life derating.
@chechito: if you’re calculating for the LHG sensitivity at MCS7 is -75 not -80… and probably calculations are done around the optimal gain frequency, 5500?
@normis: which frequency was used? Maximum distance parameters for 6Mbps G mode I assume?
Not entirely correct. Your values are per stream. SXT is dual chain, so multiply it. On our dual chain devices (all devices in the above table), MCS9 = 80 = 866
