i want to connect two Buildings via 5GHz P2P, Distance ~80m, Wireless Stations would be mount outside the Building A and inside the Building B behind the outside Wall.
I looking for a solution with lowest Latency, Bandwidth is secondary but should min. real 10MBit.
I plan to use the SXT 5 lite. But I’m not sure because one Station will be behind the Wall and the distance is very small ?
