Wireless protocol for a point-to-point link
I have a point-to-point link between 2 SXT 5HPnD devices. I leave the default option for “Wireless Protocol”: any
In the status I can check that it takes “802.11” value.
Which one do you recommend? nstreme? nv2?
The link is for a 500 meters.
Thanks for your help.
Kind regards.
802.11
Thanks!
So I will select the 802.11 instead of any.
Regards.
Try also nv2 or nstreme and select what best suits you and your conditions and circumstances.
Thanks!
How could I know which is the best? Bandwidth test?
Thank you very much.
Kind regards.
Use ONLY a PC to PC (or PC to speedtest.net) tests. Do not rely on internal speedtests of MIkrotik.
Use real data, as the user would experience. Download something from PC to PC (for example, an big movie from a shared frolder on a remote PC).
