Hi all.
I need to implement a 100m PtP link. The two antennas have unimpeded air view.
I think a couple of SXTsq Lite5 should do great.
Is there any experience in similar setups?
Any advice?
Thanks in advance.
Hi all.
Any advice?
Thanks in advance.
If it is allowed in your country think about Wireless wire
How much bandwidth do you need?
60ghz (wireless wire) will give plenty of bandwidth, and at 100m shouldnt have any issues with bad weather.
5ghz over 100m also very good, you just wont get quite as much bandwidth across it but if your requirements are only very little (in modern relative terms) then the units you suggested should do the job fine.
how much bandwidth you need ?
I need no less than 50 Mbps. Stability is better than bandwidth, in my scenario.
The V-band is not freely available in Italy. Unluckily.
Sure a SXTsq Lite 5AC can do the job, just reduce the TX power on both sides to have around -50dbm on both sides and you should be able to pass over around 100mbps with those equipments.
regards.
Would you please elaborate a little bit more on your suggestion? I am not really an expert on WiFi and RF in general. Thanks.
I have had better performance when increasing antenna gain instead of decreasing TX power.
Example change antenna-gain=2 to antenna-gain=6
This will decrease the transmit power correctly for all the data rates.
