Please help me to find wireless rackmount router for RouterOS. I need 802.11b/g/n, 1xUSB, mini omni antenna installed or integrated indoor antenna, rackmount case, LCD screen, CPU higher than dual core 2GHz, RAM 1GB enough, 6 x GigaE, 2 x SFP slot. I already has seen list of Made for Mikrotik company, but there is no wireless core router.
Check out Advantech. They make a whole range of rackmountable network appliances with onboard CF slot + SATA, LCD display, and various numbers/combination of GigE and 10GigE SFP/SFP+ ports.
I had my hands on a FWA-6480 for a day and installed RouterOS on the included industrial CF card. It recognised all the storage and the ports, but LCD display didn’t work (I think this was with ROSv3, things might have changed now). I ran a bunch of bandwidth tests to itself (port to port) over GigE and it didn’t break a sweat.
I can not send message using roc-noc form. There is always shows error. @ roc-noc.com. Could you please offer us R52Hn card with 2xmini omni antennas integrated into your Roc-Box Core?
