Hi, I’m after some advice for setting up a dual wireless link with some form of redundancy as I using a UDP bidirectional data stream for a remote control but just using 1 wireless link has been causing some dropouts in the link as one AP is on moving vehicle while the other is stationary and the distance is getting up to 100meters+
A bit of information about the current setup:
- I have a router at each end and connected to each router will be 2 wireless AP’s/Bridges - On there own Ethernet jack.
- There is a 500ms timeout before the control computer will see its lost connection to the remote and go into safe mode.
What would be best way to implement fail-over?
I’ve had a bit of search through the forums and it looks like there is a few options available but I’m not sure on what the response time are for each options.
Could someone recommend the best fail-over technique to get fast response time? Something like 100ms would be ideal!
Cameron
