I want to test a point to point link with two frequencies.
This by bonding. Does anyone know what I would use bonding best? It is intended as the 5 GHz. frequency connection is lost the 2.4 GHz. the connection would take or maintain. A redundant link.
Anyone have an idea what kind of bonding should I use?
@Spacex i know that product and appreciate that.
But i will a configuration with bonding and with sxt.
Thanks fot your reply
have a look at https://wiki.mikrotik.com/wiki/Manual:Interface/Bonding, and especially enable link monitoring, probably arp base
examples: https://wiki.mikrotik.com/wiki/Manual:Bonding_Examples
Ik denk dat de balance-xor Bonding de beste oplossing zal zijn aangezien deze de pakketten over eenzelfde verbinding stuurt totdat deze uitvalt en de ander het gaat overnemen.
I think that the active backup will be the best solution since it sends the packages over the same connection until it fails and the other one takes over.
Bonding Modes: balance-xor Bonding Packets destined for specific peers will Packets destined for specific peers will always be sent over the same interface always be sent over the same interface
Works best in a “local” network Works best in a “local” network configuration configuration
Switch ports need to be configured for Switch ports need to be configured for “etherchannel” or "trunking.
do you want an active-backup or active-active?
xor is the last one
An example, the 5 GHz. loses its connection through DFS.
The 2.4 GHz. connection must take over immediately.
That is why I would put the two interfaces in bonding.
Ether1 = 5 GHz. link
Ether2 = 2.4 GHz. link
hint balance → balances
over both links
if you want active passive that’s a different mode
the “immediate” hand over (subsecond) you can have with active-backup, see http://forum.mikrotik.com/t/bondig-wifi-links-60g-and-5g/132077/1
Looks more you Are searching for OSPF
that won’t be immediate ![]()
I try it with active-backup.
OSPF is also an option but I still have to study it. I keep this in my mind and try this later, much later ![]()
Thanks for this exchange of views
Can also add a device each side of the wireless devices then use RSTP
@ CZFan Can you give me a example how to do that?
This seems interesting to try this out
will a wireless bridge pass the xSTP related frames?
Sorry, should have stated, I never tested it, just popped in my head when I read the post, the concept is: cant draw as nice as @sindy ![]()
WL2---2GHz L2-----WL2
---RB1(With RSTP) RB2(With RSTP)-----
WL1----5GHz L2-----WL1
RB1 & 2 as a switch, i.e. all ports bridged
To be honest, I dont know, never looked into it, according to Mikrotik, it seems possible, i.e. if bridged in Stations-WDS mode you can use RSTP, etc, so I suppose it will depend on how you did the wireless config
