wireless registration table
Dear Mikrotik Support Team,
It is detected that if CPE is restarted or power fluctuation then the same CPE is showing more then 2-3-4-5 times registered and client are not getting connectivity so we have to manually remove the CEP mac from the registration table of wan1 and then client restart his/her CEP then it registered once and then he get the connectivity.
any solution for the same…?
Birender
create an access list.
do u have wds enabled? disable it if it is not absolutely necessary.
why does client cpe reboot?? voltage power issues?? sort it.
wht make is cpe??
I installed them as universal repeater and make is TP Llnk TL-WA500G distance is around 800 meters to 1000 meters and signal strength is -63 to -68 dbm and ccq is around 85% to 95% and channel i am using is 13 because in that area no one is using that channel and connectivity is stable if no power or CPE reboot other wise the same CPE is showing many time in the registration table.
r u using the cpe to connect wireless clients??
if not then using Universal repeater is a damage.
Try this. On your hotspot server increase the the number of adresses per MAC. Put 10 or more and see what happens. also check your idle timeout. (this figure should be reduced).
