Wireless roaming between different providers
Maybe noob question but I did not found it in search.
Is it possible or recomended or what is the potential problems or downsides to setup same ssid on two routers which are connected to different internet providers then create access list rules for signal strength so clients would connect to corect ap ?
In my case one of them has public static IP and other one has private - behind providers nat IP address, one is at one side of building and other is oposite side, in middle they both have good signal, but some clients which are close to one router want to connect to oposite side router for no reason or to stick to one router if they go to other side of building.
I can not make access list by macs because I dont know who will be where in what time so if it is possible this kind of roaming would solve my problem.
