hi dear mikrotik support team
i need mobility and romaing in a wireless network
in other brands when you run this service, client will connect to strongest signal.
and AccessPoints negotiate to each other to determine which AP best sees the client and will deliver best signal to client
and then the client will connect to the best signal.
My Question is: when i use capsman and caps on same ssid and channel, the above negotiation between APs will Occur?
Look at this example on my website.
Sorry ti’s is no Englisch but i hope this helps you.
Folow the printscreens a made
http://www.wirelessinfo.be/index.php/mikrotik/pages/cap
Greatings
