Wireless scan save-file should include all info
Hi there,
The current implementation of interface wireless scan 0 duration=5s save-file=temp.txt does not contain all of the information that you would see if you simply did a interface wireless scan 0 duration=5s.
Notable information missing: radio name of Mikrotik routers and ROS versions.
Terminal scan example:
Flags: A - active, P - privacy, R - routeros-network, N - nstreme, T - tdma, W - w
ADDRESS SSID CHANNEL SIG NF SNR RADIO-N
AP 6C:19:8F:CC:1B:96 5200/20-eCee/ac -43 -102 59 6C3B6B… 6.37.1
AP A0:63:91:1D:6E:F6 NETGEAR68-5G 5220/20-eeCe/ac -87 -102 15
Save-file example:
6C:19:8F:CC:1B:96,‘’,5200/20-eCee/ac,-43,802.11,privacy,
A0:63:91:1D:6E:F6,‘NETGEAR68-5G’,5220/20-eeCe/ac,-87,802.11,privacy,
More info: http://forum.mikrotik.com/t/wireless-scan-issue/103213/1
